Failed to forward the checkpoint request from peer due to memory allocation failure.
This is an internal condition related to software. Check abnormal memory utilization of any process using 'show memory'. You may need to scale down the configuration related to it. If it persists, a reboot may be required to correct the problem and contact technical support, providing outputs of 'show switch', 'show log'.
Error
Request dropped due to memory allocation failure(Message Type: %msgType%)
| Name | Type |
| msgType | String |
